- Joined
- Apr 3, 2026
- Messages
- 17
I have a 2008 Nissan Sentra, 164K on the clock, and I am having some AC issues that I'm trying to get lined out. I have owned the car since new in 2008 and the AC has always worked well up until recently.
The problems began with the airflow from the vents gradually decreasing the longer the car ran. The fan speed remained constant, but the air flow actually weakened. After shutting the car off for a few minutes, starting it back up, resulted in the airflow being completely restored. I chalked this up to the evaporator behind the dash freezing up, blocking airflow, thawing, rinse and repeat.
Some Googling resulted in the expansion valve being the likely culprit here, though I did not verify with manifold gauges beforehand (rookie mistake, I guess). Replacing the expansion valve appears to have resolved the issue (idling the car for about 15 minutes, and driving the car) and the airflow seems to be fine now. I'd really like to drive for longer, 30-40 minutes to really confirm though. I DID pull a good solid vac on the system for about 45 minutes, and it held vac for an hour with no change.
What is concerning to me are the AC pressures and the amount of R134a that the system consumed. Low size is hanging about 25 PSI and the high side is in the 170-ish range at idle. When raising the RPM to about 1500-ish, the low side drops to around 18-19 PSI and the high side climbs to 185-190. This is with am ambient temp of 85-ish degrees. I really am feeling like the low side is too low, but the high side is just about right. Obviously in hotter temperatures the pressures will be a little higher. The Nissan workshop manual suggests 18 oz of R134A, however with 18 oz charged back in the system, the low side was quite a bit lower, and the high side was in the 140-ish range. I added quite a bit more R134a and that brought the pressures on up slightly to where they are now.
I am experiencing the low side/suction line frosting heavily now. With the fan speed on low/medium, the line frosts up pretty fast (less airflow through the evap), and when I turn the speed to high, the line thaws out for a couple minutes before frosting back up yet again. I'm thinking this is not normal, and will result in the evaporator freezing up (again), putting me back at square one.
Verified stuff
- The radiator/condenser fans operate properly and pull a ton of air.
- The compressor is engaging, but does not seem to cycle (at idle anyway). It kicks on and stays on as long as the "AC" button is pressed.
- I have verified there are no leaks in the system (sniffer and UV dye).
- I have verified the cabin air filter is not clogged or causing a restriction (it's new).
- No abnormal noises from the compressor when it is running.
- Static pressures (once stabilized) are about 100-110 at about 80 degrees ambient.
- Vent temperatures with the fan on max is about 38-39 degrees, and it holds this temperature.
- Vent temperatures with the fan at 50% fall to about 35 degrees.
Service performed
- Replaced expansion valve.
- New-o-rings.
- Vac'd system for 45 minutes.
- System held vac for 1 hour.
- Charged system back w/ 18 oz R134a.
- Noted pressures slightly low, added more R134a to compensate.
My questions are,
1. As the Low/suction line is frosting heavily, does this indicate I still have an underlying issue somewhere, and what does that point to?
2. Are my pressures normal for 80-85 degree ambient air? (20-25 / 150-170)
3. Have I potentially overcharged the system trying to compensate for the lower pressures? I can obviously pull some ref back out if needed.
4. Am I still potentially undercharged? (I don't see HOW, but considering the suction line is frosting..)
Verified stuff
Service performed
- New-o-rings.
My questions are,
