Should I buy Thorogood 1957 boots?
For a while now I've been needing a good pair of work boots strictly for yard work, from early Spring through late Fall. My requirements are pretty simple: be durable, be tall enough to keep debris out with my pants leg pulled down over them, provide more ankle support than the usual worn out pair of running shoes I use, and be waterproof. My boot research on Youtube has led me down a deep, very strange rabbit hole, but I think I've found the boots for me. That would be the Thorogood 1957 Series Waterproof Moc Toe Maxwear90 Boots. They seem to check all the boxes. I can get them on GovX (wife is govt employee) for $201.99 which is around $90 cheaper than anywhere else I can find. Do any of you have this boot and if so, can you think of any reason I shouldn't pull the trigger especially at this price?
I’ve had several pairs of Thorogood boots and have always gotten great wear and comfort from them. I shy away from the moc toe style though as I tend to grind the moc seams off of the toe because I somehow end up crawling a lot under houses. Always got good deals on them due to union firefighters discount
I’ve had several issued pairs of Thorogood boots - Flight boots, Working boots - and they have all been great. So, I can recommend the brand, if not the specific model.
I've worn Thorogood boots for years. Have tried redwing, wolverines, timberland, and Carolina boots in the past, but they never lasted. I usually get a year out of the thorogoods. I'd buy them all day long at that price.
Thanks, all. Sounds like the Thorogoods will work well for me, and I'll probably get at least a few years out of them before they need work, since I won't be using them in an industrial or construction setting. I'll order a pair from GovX soon.
I don't have those exact ones but I've got a pair of Thorogood moc toes that are very similar. Other than being a bit of a pain to lace up, they are very comfortable and have held up extremely well. I just took them to my local shoe shop and had them cleaned and conditioned. He said they weren't ready for new soles yet.
I used Sno-Seal on mine when new. It is a hard beeswax. Helps to have a hair dryer or heat gun when applying it. Works excellent though, soaks in deep, keeps the leather supple, and lasts a long time. But like most shoe leather conditioner/sealers, it will darken the leather some, just FYI.
