Originally Posted By: BrianWC
I agree w/ drivewaytech. Figure out the PCV system. It HAS to have one. As for the cleaning, ditto. If he has the time, pull the pan and valve cover and get as much crud out by hand as is possible to do safely. Then resume arx-ing. Sure arx could probably take it all out eventually, but if you're THAT worried that it faces imminent death, go ahead and give it a helping hand. Try a spray bottle and fill with Chemtool and try to wipe off w/ a rag. There was a guy on here about a year or so ago that did the kero thing on a yota and he had to drop the pan several times to clean it out.
I think this is a good approach to take. If you can at least get the valve covers off, you could remove a bunch of sludge by hand. I don't know enough about these engines to suggest what else to remove.
I'd also look at the PCV system and try to find that valve.
