Hello,
I have 2001 Volvo S80 (2.9L non-turbo engine) with a notably-fragile GM 4T65E transmission. Recently, the car lost forward drive and produced the Volvo-specific error code TCM-053: Lock-Up Pressure Switch Jammed.
Hoping for more information before I sent the car to a shop, I sent an ATF sample to a lab, specifically ALS Oil in Portland, OR, via a WIX kit. They returned a clean bill of health, and I am seeking a second opinion.
This is the full report:
For additional context, the ATF is Valvoline Dexron VI, and I did a drain-and-fill about 3000 miles ago.
Do you see anything useful here that I can share with a mechanic? I would greatly appreciate any insight.
Metals | ppm |
Iron (Fe) | 158 |
Chromium (Cr) | <1 |
Lead (Pb) | 23 |
Copper (Cu) | 53 |
Tin (Sn) | 12 |
Aluminum | 2 |
Nickel (Ni) | <1 |
Silver (Ag) | <1 |
Titanium (Ti) | <1 |
Vanadium (V) | <1 |
Contaminants | ppm |
Silicon (Si) | 10 |
Sodium (Na) | <1 |
Potassium (K) | <1 |
Additives | ppm |
Magnesium (Mg) | 1 |
Calcium (Ca) | 138 |
Barium (Ba) | <1 |
Phosphorus (P) | 207 |
Zinc (Zn) | 40 |
Molybdenum (Mo) | <1 |
Boron (B) | <1 |
Contaminants | |
Water (%) | <0.05 |
Physical Tests | |
Viscosity (cSt 100C) | 5.6 |
Solids (%) | 0.2 |
Physical / Chemical | |
Acid Number (mgKOH/g) | 0.72 |
