I drive about 60k per year. 90% highway driving.
Schaeffer's 10W30 SYN BLEND 7000.
Oil had 15,029 miles when last changed.This is the third Analysis done at Schaeffer's oil Lab. Mixture of Winter/ Spring driving. This 2005 Chevy Aveo with 1.6 ltr engine has 72,790 miles. Three PureOne oil filters were used, each PureOne changed at 5000 mile interval. Only oil added as make up oil. Air filter has been changed now. Oldest report is on left - newest on right.
Silicon *Dirt, sand} High. Oil should be changed. Resample at normal interval to establish trends.
[ April 26, 2006, 12:13 AM: Message edited by: 59 Vetteman ]
====================================code:
Miles on unit 40,480----57,761----72,790
Miles on oil 15,400----16,927----15,029
Wear Metals PPM
Copper 13----10--- 04 normal 0 - 40 ppm
Iron 29----- 99--- 40 normal 0 - 100 ppm
Chromium 2--- 4--- 02 normal 0 - 40 ppm
Aluminum 7---10--- 04 normal 0 - 40 ppm
Lead 2----- 3--- 01 normal 0 - 50 ppm
Additives PPM
Molybdenum 324----- 345---262 normal
Phosphorus 1005----1079---801 normal
Zinc 1167----- 1236---892 normal
Magnesium 10------ 16--- 9 normal
Calcium 3061----- 3232---2349 normal
Contaminants
% antifreeze 0---- 0--- 0 normal
Fuel Dilution N---- N--- N normal
% H20 .0------- .0---.0 normal
Silicon 19--- 24---23 normal / Abnormal / Abnormal
Oil Properties
Viscosity 9.70---- 10.26--- 10.36 normal for 30W 9.30 - 12.49
SAE ISO 30 W 30 W --- 30W normal
Sulfur 7---- 23 --- 13 normal
Oxidation 12---- 27 --- 21 normal
Nitration 30---- 41 --- 30 normal
