Looks like my numbers are somewhat trending towards the current formula now. I was unaware the formula had changed so i was mixing bottles before causing a lot of confusion.
My reason for changing at low miles was due to MIL and I was going on a trip towing my camper.
Previous UOA HERE
Code
COMMENT: There are no complaints to file regarding your the EcoBoost in your Expedition. Wear metals
are lower this time after the shorter run and there's nothing wrong with that. Iron was a bit high in June of
last year, but in both samples since then, iron's wear rate (ppm/mile) has improved. We don't see any
reason why you couldn't try 6,000 miles on the oil again. The TBN of 4.2 shows active additive left for a
longer run and fuel dilution dropped to 1.3%. That's just from normal use rather than a fuel system problem.
Looking good from here at 21,030 miles.
MAKE/MODEL: 2017 Expedition 3.5L EcoBoost
OIL Castrol EDGE 0w-40 Castrol EDGE 0w-40 Castrol EDGE 0w-40 Ford 5w-20? Ford Factory
MILES IN USE 4084 4963 5500 5148 1338
MILES 21030 16946 11983 6486 1338
SAMPLE TAKEN 7/21/2019 1/6/2019 6/10/2018 9/24/2017 4/14/17
ALUMINUM 4 5 6 7 15
CHROMIUM 1 1 2 1 1
IRON 19 32 59 22 27
COPPER 13 12 19 30 100
LEAD 0 0 2 0 1
TIN 0 0 0 0 0
MOLYBDENUM 12 60 6 26 70
NICKEL 0 1 1 0 0
MANGANESE 5 6 10 7 18
SILVER 0 0 0 0 0
TITANIUM 35 6 36 0 0
POTASSIUM 4 3 3 2 11
BORON 23 123 40 80 165
SILICON 11 16 22 32 261
SODIUM 8 6 6 9 9
CALCIUM 1975 2764 2176 1895 1728
MAGNESIUM 382 15 12 9 9
PHOSPHORUS 819 849 790 704 640
ZINC 919 947 897 761 659
BARIUM 0 0 2 14 1
SUS VIS 210?F 65.3 60.9 59.1 54.8 49.6
cSt @ 212?F 11.69 10.47 9.96 8.70 7.14
FLASHPOINT F 360 325 350 375 355
Fuel% 1.3 3.0 1.8
Antifreeze% 0.0 0.0 0.0 0.0 0
WATER% 0.0 0.0 0.0 0.0 0
INSOLUBLES 0.2 0.1 0.2 0.3 0.2
TBN 4.2 4.6 3.0 3.6 3.8
Previous UOA HERE
Code
ALUMINUM 4 5 6 7 15
CHROMIUM 1 1 2 1 1
IRON 19 32 59 22 27
LEAD 0 0 2 0 1
TIN 0 0 0 0 0
NICKEL 0 1 1 0 0
SILVER 0 0 0 0 0
SODIUM 8 6 6 9 9
BARIUM 0 0 2 14 1
Fuel% 1.3 3.0 1.8
