Good morning,
Here is the second UOA on my 2001 Nissan Xterra. While the oil change after the summer travel season showed extremely low wear numbers, this one was higher. I expected as much because in winter my driving habits are usually only to day care, the grocery and band practice...no long trips except for maybe once a month to Boston.
Here's the skinny:
ALUMINUM 4
CHROMIUM 2
IRON 11
COPPER 7
LEAD 13
TIN 0
MOLYBDENUM 98
NICKEL 0
MANGANESE 1
SILVER 0
TITANIUM 0
POTASSIUM 2
BORON 3
SILICON 18
SODIUM 4
CALCIUM 1700
MAGNESIUM 5
PHOSPHORUS 692
ZINC 866
BARIUM 1
Viscosity 63.0
Flashpoint 395
Fuel Coolant 0.0%
Water 0.0%
Insolubles 0.4%
You mentioned that you thought it might be kinder to change out the oil sooner rather than later, since your winter driving habits differ from summer. We think you're right. This oil was in use fewer miles than the last, and wear increased quite a bit. Nothing is high enough to worry about -- in fact, your wear levels are still right around average for a 3.3L Nissan engine. But your bearing wear increased enough that we like your idea of changing the oil sooner in the winter. No gas, coolant, or moisture was present in the oil. Overall, things look good! Check back.
Now, I can't explain the Silicon, still going up. I re-oiled my K&N...might have to try the paper filter this time...It was good to see the insolubles down...still a good report IMO...
Bogatyr
[ February 06, 2004, 08:13 AM: Message edited by: Bogatyr ]
Here's the skinny:
ALUMINUM 4
CHROMIUM 2
IRON 11
COPPER 7
LEAD 13
TIN 0
MOLYBDENUM 98
NICKEL 0
MANGANESE 1
SILVER 0
TITANIUM 0
POTASSIUM 2
BORON 3
SILICON 18
SODIUM 4
CALCIUM 1700
MAGNESIUM 5
PHOSPHORUS 692
ZINC 866
BARIUM 1
Viscosity 63.0
Flashpoint 395
Fuel Coolant 0.0%
Water 0.0%
Insolubles 0.4%
Bogatyr
