Nick1994
$100 site donor 2023
We've got an 18 year old York 3-ton package unit that has a gas furnace. It works great and has been extremely reliable. I noticed that for the past week there was a squeaking noise when it was running. I called out a local chain HVAC/plumbing repair company, they're rated well here. I was outside with the guy and he popped off the side cover and immediately saw that the squirrel cage fan for the ducts was badly loose. After wiggling it it actually wouldn't come back on so we had no heat, but not an emergency here in Phoenix. We have space heaters too.
Anyways, we were quoted $1,700 for a new fan motor but they recommended if fixing it to replace the squirrel cage fan because it was dirty, for a total of $2,200. They actually recommended a new HVAC system which they said would start at $12k, which is also a total joke. I paid the $79 and he left. I took the side cover off myself and the 2 screws that hold the fan assembly in and slid it out within 5 minutes. Realized the motor is fine, but the bracket that holds the motor had a broken leg.
Went to Grainger and got a bracket but it was too small. Went back and got another one that I had to drill new holes in at the end so it would fit the bolt pattern (barely). Also had to use some spacers for the screws so it wouldn't hit the fan. I cleaned the fan assembly with a small brush and blew it out with the leaf blower, worked perfectly. It runs as quiet as ever now. Probably more airflow without so much buildup on the fins. $27 for a new bracket.
Even if just the motor was bad, I took the part number to Grainger and they sell the motor for $210. So the HVAC company makes $1,500 on the install?
I guess the lesson learned here is to be observant and not too trusting. We just need maybe 2 more years out of this unit. The entire house will be getting remodeled and the unit needs to be replaced with a new larger one, relocated to the roof with new duct work, so expensive repairs and a replacement isn't a good option just yet. And yes, the loose insulation was taped up before the cover was put back on.
