Loved those old M35 deuce-and-a-half's. The last unit I was in before retiring about 12 years ago still had three of them. Many M35's soldier on, a lot of them working for rural fire districts as brush trucks or water tenders.
Why does it say:
11:00 Single ---- Tires ---- 9:00 Duals
What does that mean?
You have to run narrower tires on axles running dual tires. If you run dual 11:00 tires the sidewalls likely will rub. I had that problem on my CCKW wirh wide tires.
And they will run on almost any flammable liquid. But if you run gasoline, you need to add oil to the fuel so it lubricates the injector pump.
Seems like 100 years ago when I was the maintenance officer for a Signal company in the Army....
Why does it say:
Are they literally called "eleven o clock tires"? I am not understanding how the time type name is applied to the type of tire.
