Is it bad to only fuel up when you hit E, which for some car means there is still 2 gallons left. I recently ended up with only 1/3 gallon left because there was no safe place to pull over to refuel on a long stretch of I-10. The 02 Accord ran fine and no indication of poor performance or stalling. When I refueled, it took 16.4 gallons. The total capacity is 17.2 and I know one can't truly fill up the entire 17.2 on the first click of the pump, so I would think there was about 1/2 gallon left in the tank when I refueled. Normally, I refuel when it hits E because it takes only 14 gallons out of 17.2 when E is reached.
Is the "myth" of fuel pump failure really true or just a urban legend to get people to needlessly driving around with burden weight. I would think a fuel pump would know to shut itself off if it overheat.
