Morning Bitog,
My 09 Accord v6 has a harmonic rumble at 70-75 only. It had it when i I acquired it from a relative so first thing I did was replace the old tires with brand new Michelin premier a/s, and even after a few rebalances at a couple different places, all agreeing with each other that the tires are perfectly balanced, the rumble persists. I also replaced all pads and rotors with new Honda OEM, and when doing some work took a look at the suspension pieces which also appeared perfect.
The car only has about 29k on it, and the VCM has been disabled for quite some time so it's not a VCM related vibration.
Any ideas brain trust? Can a bad alignment cause this? It seems to steer true but I know that's not always accurate
Thanks
Thanks
