Originally Posted By: JOD
Originally Posted By: ltslimjim
^Yes, different media. IMO, RP/M1/K&N all have their strengths. K&N is probably best for racing, M1 is a middle ground, and RP probably has slightly higher efficiency rating.
I think the only thing that makes the K&N 'better for racing' is that it says 'K&N' on it...
I posted a flow chart for the RP 20-820 a while back (unfortunately I don't have it on this computer, and I can't find the link on here). The filter seems to flow better than just about anything out there, with the possible exception of the Ford Racing filter (the test parameters were different, so it wasn't a straight-up comparison).
The RP filter really seems like a more robust design than either the M1 or the K&N (which I *think* are identical filters); the full synthetic glass media with metal screen backing is definitely different that the synthetic blend media used in the other filters.
So Jim, putting the filter back together from your pictures, I'm assuming the bypass is in the base?
You're probably right regarding K&N, to an extent with the brand sell, but I'd imagine some apps it allows for best 'flow', of course then there is the pressure argument as well. Again, an attempt to generalize fails. Ugh!
They are different compared to an M1, though.
