I was wondering if it is fine to do a 10,000 mile oci with royal purple
only a used oil analysis can tell you for sure..but with a good running engine a quality filter yes you should be able to or come close with your driving style.
take it out for a good rip once an a wile
Thanks! the vehicle is a 2005 chevy tahoe 5.3, it is a great running engine but it has been serviced at a garage down the road for half its life and they use lousy advanced auto parts oil, im wondering what effect it will have on the engine going from garbage to the best
Well only positives,,will get a good cleaning for one running syns.
Well there is one possible negative which is actually too much of a positive. If the advance oil caused the engine to not be totally clean, cleaning it could expose leaks in the seals.
Fortunately, Advance doesn't make their own oil but contracts out to Warren who does make good oil so you should be fine but there's always a chance of a bad reaction. You should try all of the synthetic offerings to see which one your truck reacts best to.
