Good point. I knew the API RP was more geared at warranty compliance over performance/max protection. Not that the API is bad but for the price I'd agree you have options just as good. HPS and XPR is there creme of the crop oil.Royal Purple HPS is a different oil blended to a higher spec over the pcmo ,both are fine oils for a specific market need, the pcmo is a competitive oil to other SQ,GF-7 brands and is not considered inferior, though more pricey, myself I can find better oils at Walmart ,only to fit my needs & there is no reason not to use RP oil, stop the usual bashing other oils than Mobil 1 ,which is a good oil too. Mobil 1 is not the only player on the market.
Film thickness, not film strength.Also liking the stout HTHS and viscosity index of the European spec oils. Having less potential shear is always a plus as you get the best possible film strength and boundry lubrication.
How is film strength being measured?Well it's a good indicator along with the added HTHS as it goes in hand. Lower VI index will usually shear the most especially on higher viscosity spreads like a 0w40 or 5w50 etc.
Well if your motor runs quieter and the used oil analysis shows normal or even below that I'd say its measured really good.How is film strength being measured?
Right. Good thinking.Well if your motor runs quieter and the used oil analysis shows normal or even below that I'd say its measured really good.
Nothing that actually gives a definitive answer but the main thing I'm looking at is copper, chromium and iron. If that looks good or better than good I'd say film strength has to be stellar because the name of the game is keeping metal surfaces from touching as much as possible from a wear standpoint.Right. Good thinking.
But I'm still a bit confused as to what you look at on the UOA that gives film strength? And what's a normal value?
I trust the approvals an oil has way before I trust an untrained interpretation of a $35 spectrographic analysis. But maybe that's just me.Not saying its guaranteed but just by numbers not many others look that good. Of course a used oil analysis will be more definitive as if you're not testing your trusting.
No.On the 2.0 Kia MPFI looking at either the 5w30 restore and protect, european XL3 5w30 or 5w40 european. Would the 40 operating viscosity be too thick for that motor? Really liking the european route but if it don't help then no reason to use.
How long OCI do you plan to do with it?Mobil 1 ESP 0W-30 is what my Jeep Wrangler gets.
I do 5k oci’s. Severe service.How long OCI do you plan to do with it?
Are you gonna do UOA after that?I do 5k oci’s. Severe service.
Probably at some point next year.Are you gonna do UOA after that?
