Yesterday I changed my '88 Accord from 10w-30 Mystik to Rotella Synthetic 5w-40. I was hopful that the Rotella would work well in this higher mileage car (162,000 mi) that is used for short trips.
This morning I started up the car and there was much more engine noise than usual. Sounded almost like piston slap, but more so (perhaps a bit of rod knock). I immediately killed the engine and checked the oil to make sure. Level was fine with very fine bubbles on the dipstick.
After the engine warmed up the noise abated somewhat, but is still greater than usual. I will probably change out the Rotella tonight.
Funny thing is, I ran the engine last night to check for leaks and the noise did not seem to be there. Going up to a 40 wt shouldn't make this much difference.
Thanks for any comments or advice.
[ June 09, 2003, 10:17 AM: Message edited by: tgharch ]
