Originally posted by brianl703:
Do you put the ramps right up to the front tires or do you leave some space so as to get a running start before the tires have to go up onto the ramp (the front edge of which is 1" higher than the ground it's sitting on, if I recall correctly).
Last time I used them I put them right up to the front tires, and later I thought it might work better if I left a foot or so of space so as to get a running start, but I just decided to get a jack instead and never did use them again.
