Until my current fill I've been following a 5k interval on my Focus whether using a conventional or a blend, etc. As the sig says, I'm currently using M1 AFE 0w-30. Usually use a 20 grade but... AZ clearance.
I generally use the car 5 days a week, to and from work only, parked the whole weekend. Maybe in the evening I will use it to make a short trip into town, 5 - 7 miles total, maximum. Otherwise, my daily commute is about 14 miles each way. Definitely reaches operating temp but I'm wondering if it borders on short-trip territory. I drive moderately, red line maybe once every week or two.
I'm set on using a full syn 0w/5w-30 (I do have, I think 6 quarts of Magnatec 5w20) for the foreseeable future because that makes up most of my 55qt stash to be shared between the whole fleet.
Also, using a Motorcraft filter, next OCI or two will be Bosch distance plus (WM clearance).
I was going to go a full 10k interval on this M1 AFE but as I'm at about 7k and I'm wondering if the short-ish trips and everything mean I should go with 7 - 7.5k.
What say you, BITOG?
