JHZR2
Staff member
This is redline 75w-90 from the 4.10 LSD in my 1991 BMW 318i. The 318i doesnt use a standard BMW diff, it is slightly smaller and has slightly less capacity. The cover is finned, but I believe the oil gets very hot. BMW recommends Castrol XJ fluid (IIRC) which is a 75w-140 in all LSDs based upon a TSB. I refilled with a Specialty Formulations diff fluid and definitely found that the diff quieted a bit (these diffs are also known to be a bit whiny).
Code:
Sample Date 1/13/2008
Unit Age 111425m
Comp Age 111425m
Time on Oil 9925m
Oil Maint. Changed
Fluid Redline 75w90
Fe 188
Cr 2
Ni 1.2
Ti 0.6
Ag 0
Al 11
Pb 0.1
Cu 0.6
Sn 1.6
Si 166
Na 2.4
K 1.5
B 146
Ba 0.3
Mo 7.5
Mg 0
Ca 70
P 831
Zn 31
S 14997
Cd 0
Mn 3.7
V 0
Sb 0.2
Kv@40°C142.6
White Metal NONE
Babbitt NONE
Precipitate NONE
Silt NONE
Debris NONE
Dirt NONE
Appearance NORML
Odor NORML
H2O(Emul) NEG
H2O(Free) NEG
Code:
Unit Age 111425m
Comp Age 111425m
Time on Oil 9925m
Oil Maint. Changed
Fluid Redline 75w90
Fe 188
Cr 2
Ni 1.2
Ti 0.6
Ag 0
Al 11
Pb 0.1
Cu 0.6
Sn 1.6
Si 166
Na 2.4
K 1.5
B 146
Ba 0.3
Mo 7.5
Mg 0
Ca 70
P 831
Zn 31
S 14997
Cd 0
Mn 3.7
V 0
Sb 0.2
Kv@40°C142.6
White Metal NONE
Babbitt NONE
Precipitate NONE
Silt NONE
Debris NONE
Dirt NONE
Appearance NORML
Odor NORML
H2O(Emul) NEG
H2O(Free) NEG
