1998 Chevrolet S10 ZR2 Schaeffer's 7000 5w30 3484m
JHZR2
Staff member
New Jersey
This is the most recent UOA from my 98 Chevrolet S10 ZR2. I dont put a lot of miles on the truck, and it gets starts only a few times a month at best. It sits outside sometimes, in a garage other times. Schaeffer's 7000 5w-30
Hopefully the thing displays OK.
Code:
Unit Age 57000m 53800m 48759m 46494m 45640m 43640m 36603m
Comp Age 57000m 53800m 48759m 46494m 45640m 43640m 36603m
Time on Oil 3484m 2206m 3119m 854m 1661m 3361m 1790m
Time on Fltr 3484m 2206m 3119m 854m 1661m 3361m 300m
Fluid Sch 7000 GC Cas Start-up GTX 5w-30 ACD 10w-30 GTX 5w-30 GTX 5w-30
Fe 4.4 7.8 4.4 3.2 15 7.5 3.5
Cr 0.3 0.5 0.9 0.2 1.4 0.2 0.1
Ni 0.9 0.4 0 0.2 0.9 0.3 0.9
Ti 0 0.1 0 0.1 0.6 0 0.1
Ag 0 0 1.5 0 0 0 0
Al 4.4 1.5 6.9 2.6 3.9 1.5 2.6
Pb 4.2 0.1 0 1.7 9.8 7.1 2.7
Cu 5.1 2.6 1.5 3.8 20 31 1.4
Sn 3 0 0.8 0 0.2 0 2.2
Si 12 12 5 12 33 9.2 8.5
Na 3 5.7 2.5 3.1 5 17 3.9
K 9.5 2.4 30 12 94 446 40
B 8.4 1.7 2.2 9 62 2.1 1.3
Ba 0.3 0 0.3 0 1.4 0.3 0
Mo 198 2.9 71 39 48 46 53
Mg 11 375 7.1 14 47 53 12
Ca 1658 1629 2089 1673 2467 1979 2015
P 564 798 866 782 765 740 907
Zn 639 873 789 822 836 849 907
S 2504 2497 2856 2800 4712 2634 3117
Cd 0 0 0 0 0 0.1 0.2
Mn 2.3 0.4 1 0.3 2.4 2.5 0.3
V 0 0 0 0 0 0 0.1
Sb 1.6 0 13 1 0 2.4 0
Glycol 0 0.1 0.1 0
Soot(%) 0 0 0 0 0 0 0
Oxid(PA) 15 11 20 80 30 35
Nitr(PA) 7 10 15 0 40 45 20
Sulf(PA) 12 9 10 13 87 7 13
ZDDP 14 13 -0.02 0
Kv@100°C 9.8 11.9 10.66 10.4 10.59 10.7 10.18
White Metal NONE NONE NONE NONE NONE NONE NONE
Babbitt NONE NONE NONE NONE NONE NONE NONE
Precipitate NONE NONE NONE NONE NONE NONE NONE
Silt NONE NONE NONE NONE NONE NONE NONE
Debris NONE NONE NONE NONE NONE NONE NONE
Dirt NONE NONE NONE NONE NONE NONE NONE
Appearance NORML NORML NORML NORML NORML NORML NORML
Odor NORML NORML NORML NORML NORML NORML NORML
H2O(Emul) NEG NEG NEG NEG NEG NEG NEG
H2O(Free) NEG NEG NEG NEG NEG NEG NEG
Silicon looks a tad high. Is it an additive package component? You wouldn't be running a K&N "rock-catcher" by chance would you. All and all wear looks pretty good for a 4.3 V6 and you don't have a coolant leak...YAY!!!
Nope, I actually changed from an AC Delco to an Amsoil EAA though. Consistent Si at least... two different oils, so Im not sure. The intake system is tight, though I open it now and again.
