Break-in oil on a CAT
NM
I have a thread in the bypass section about an install on a CAT C-18.
Here is a sample pull from one of those C-18's.
Cat C-18
Factory filled with 19 gallons of CAT DEO 10w30
Factory full flows (2)
Bypass Filtration
315 hours on this sample.
Oil has not been changed.
Here are the details.
TestPkg MOB 2
Sample Date 8/16/2012
Unit Age 315h
Comp Age 315h
Time on Oil 315h
Time on Fltr 315h
Oil Maint. Not Changd
Fltr Maint. Not Changd
Offline Fltr Maint Not Changd
Fluid Typical | Base CH036
Fe 9.6
Cr 0.2
Mn 0.5
Ni 0.3
Ti 0.3
Ag 0.0
Al 0.9
Pb 1.0
Cu 7.7
Sn 0.0
Sb 0.0
V 0.0
Si 6.9
Na 1.7
K 6.8
B 74
Ba 0.0
Mo 18
Mg 412
Ca 2229
P 1333
Zn 1293
S 3965
Cd 0.0
Soot(%) 0
Oxid(PA) 48
Nitr(PA) 42
Sulf(PA) 47
ZDDP 18.
EP H2O 5.
Anti-Oxid 1.
Synth BD1 0
Synth BD2 0
Gasoline 0
IR Other 112.
TBN 10.5
Kv@100°C 13.83
Grade SAE 40
Fluid Type SAE_ENG_DE
>4µm(c) 2µm 1269
>6µm(c) 5µm 691
>14µm(c) 15µm 117
>21µm(c) 25µm 39
>38µm(c) 50µm 6
>71µm(c) 100µm 0
ISO Code 17/14
NAS 5µm 9
NAS 15µm 9
NAS 25µm 9
NAS 50µm 9
NAS 100µm 1
White Metal NONE
Babbitt NONE
Precipitate NONE
Silt NONE
Debris NONE
Dirt NONE
Appearance NORML
Odor NORML
H2O(Emul) NEG
H2O(Free) NEG
Not familiar with the CAT oil; is it CJ-4 compliant?
The TBN is very strong after 300 hours.
Wear, as expected with bypass, is very low.
Soot at zero?
Lot's of hours left in that load.
My two favorite lines above:
"Appearance NORMAL"
"Odor NORMAL"
Yeah - but how's it taste?
Yes it is a CJ-4 compliant.
The ROI comes really quick with these engines.
Soot at zero?
Pretty typical. If the number rises even the slightest on the used oil analysis i can go out and usally find a exhaust leak getting sucked into the intake. Those can be fixed quickly.
I think I will go out and pull another used oil analysis in about a week. Should be over 500 hours then.
"Appearance NORMAL"
"Odor NORMAL"
Taste like chicken! I can cut quite a bit of info out of the used oil analysis report. To much data.
Preumably a conventional oil?
Correct.
Another great example of how properly spec'd fluids can provide stellar performance, even if they are (gasp) thinner and of conventional stock.
