2013 F150 5.0 Castrol Edge 5W-20 9557 miles
upstate NY
Code:
Edge 5W-20 Motorcraft 5W-20
9557 miles 5607 miles
7/31/17 - 5/13/18 March '17 - 7/31/17
Milton Cat Lab ALS Atlanta lab
Copper 2 2
Iron 17 10
Chrome 0 0
Aluminum 7 5
Lead 0 0
Tin 0 2
Silicon 9 3
Sodium 3 4
Potassium 3 5
Boron 65 60
Moly 65 18
Nickel 0 0
Silver 0 0
Titanium 6 0
Calcium 2207 2249
Magnesium 9 4
Zinc 785 671
Phos 604 602
Barium 0 2
Oxidation 27 n/a
Nitration 13 n/a
Sulfation 46 n/a
Water Neg
Antifreeze N No
Fuel N
Visc@100°C 9.7 8.3
TAN 6.19 n/a
TBN 2.3 3.2
No oil added No oil added
down half quart was still full
This oil was run for over 9 months that included the entire winter, some of which was brutal. The truck does many trips of 2-7 miles (over the course of the oci). Some days it accumulates 40-70 miles over a few hours time. No highway cruising. Sometimes we go into Binghamton or Syracuse and do some city driving, but it's an insignificant portion of the miles.
No towing, but some hauling stuff in the bed. From a 750 pound ATV to a load of scrap metal (1700 lbs), but like the city driving, it's a small portion of the miles. It's driven gently, mostly below 1700 rpm. Maintaining 55 mph up 13% grades (even loaded with the ATV) requires a drop to 4th gear at 2300 rpm and that's as close to an Italian tune-up as it ever gets. No redline runs for me.
I replaced this oil with 5W-30 but as you can see, this oil had already thickened into a 30. And yup...the TAN over took the TBN.
I'm going to start using Milton Cat for all of my samples. The base price is $18.99 and the TBN/TAN are $8.xx each. I can drop samples at one of their locations and their parts delivery truck picks them up when making the rounds, and gets them to the lab. It's less stressful than mailing.
Pds indicates its KV@100*C as 8.88 cSt.
At shear-thickening of 10ish %, 10k metal wear rates is great with residual TBN of 2.3.
'High' TAN of 6.2 is of least concern.
Nice low wear; Fe still trending down slowly.
Contamination in control.
Crossover cautionary, but not causing an issue yet.
These are great wearing engines.
Originally Posted By: dustyroads
Code:
Copper 2 2
Iron 17 10
Chrome 0 0
Aluminum 7 5
Lead 0 0
Tin 0 2
Silicon 9 3
Sodium 3 4
Potassium 3 5
Boron 65 60
Moly 65 18
Nickel 0 0
Silver 0 0
Titanium 6 0
Calcium 2207 2249
Magnesium 9 4
Zinc 785 671
Phos 604 602
Barium 0 2
Oxidation 27 n/a
Nitration 13 n/a
Sulfation 46 n/a
Water Neg
Antifreeze N No
Fuel N
Visc@100°C 9.7 8.3
TAN 6.19 n/a
TBN 2.3 3.2
The odometer reading when this Edge was drained was 96846
The odometer reading when the Motorcraft was drained was 87289
I bought this truck in March of '17 with 81k miles on it.
I'm a bit surprised that the oil thickened but as you noted, it's not a lot. At least it's not grossly out of grade. I don't have a VOA of this oil to get an accurate comparison, though. I have a VOA for the new oil that just went in so I can compare next time.
I'm not concerned about the TAN at all. I'm aware of the concerns about TBN/TAN inverting and indicating that the oil is spent, but I haven't seen a problem in my sample results when it happens.
