Dyson Analysis
Oil Brand/Weight : Redline 5w-30
Type Equipment : Toyota Sienna
Miles/Hours on oil : 4812
Total Miles/Hours : 78905
Results ppm/% Comments (blank=normal)
Wear
Copper 0
Iron 0
Chromium 1
Lead 0
Aluminum 2
Silicon 12
Tin 2
Additives
Molybdenum 542
Sodium 11
Magnesium 25
Zinc 1170
Potassium 14
Phosphorus 1070
Calcium 2310
Physical Properties
Water negative
Fuel negative scale negative,trace,positive
Antifreeze negative
Soot 40 some solids present,
sludge precursors being cleaned
Oxidation 94 scale 0-199 47% cleaning going on.
Nitration 87 scale 0-199 43.5% elevated by
Redline signature
Sulfur 71 some fuel sulfur, mostly Redline
adds
TBN 7 some depletion as cleaning takes place
Vis@100 C 11.8 30W
Final Comments : Engine wear very low, silicon average to low includes oil adds. NOx, Oxd elevated by Redline signature as is sulfur and solids. Confirm ignition components are in good repair and fuel economy is normal. Oil is in
excellent condition considering cleaning, continue use if not changed to 7000 miles.
Next interval may be taken to 10,000 miles after clean up has stabilized.
Questions let me know.
I like this oil and engine combo once cleaned up internally. This one of few oils and engine where cleaning didn't kill the lubricity of the oil.
Wear
Copper 0
Iron 0
Chromium 1
Lead 0
Aluminum 2
Silicon 12
Tin 2
Additives
Molybdenum 542
Sodium 11
Magnesium 25
Zinc 1170
Potassium 14
Phosphorus 1070
Calcium 2310
Physical Properties
Water negative
Antifreeze negative
Redline signature
adds
Vis@100 C 11.8 30W
