Since my Cherokee is not my primary vehicle and doesn't see the majority of miles, I usually change once a year. That can be 3000 miles or 6000 miles. I'm going to hit probably 8000 miles before my next "scheduled" spring oil change. I have no issues running my Focus that long but the Jeep is a different use. It has 203000 on the Odo, 2000 miles on the current oil/filter which is Supertech 10w30 synthetic and 1 quart of Pennzoil Platinum 10w30 and a Supertech ST16 filter.
Usually every other weekend this summer I have been on the trails. That pretty much means running all day.
Over this weekend I towed my popup camper through the hills of PA (so some of the hills were pulled at 3500RPM) to an off road park, then bounced it around in the rocks all day with the A/C on full blast. 90 degrees. Never shut it off because 2000/2001 Cherokee 4.0L will not start hot. They sputter warm , but heat soaking after this will cause them to not start.
Next weekend there will be a similar trip. There are at least 4 more trips like that for this summer. I have already done 4 or 5 such trips.
Recommended OCI is 5000. Severe is 3000. What do you all think?
This is for fun. Not serious.
