Please show and explain how you are filtering it. Also I have noticed synthetic oil does not like to burn too well, is that an issue?I burn all my used motor oil in my 2019 denali diesel.
Oh, its had a 12v Cummins swapped in from 1992 and had 700k miles on it before installed.
Came with auto rust- stop.
Gylicerin gauges are the best. Watch oil pressure needle flutter with each plug fireI loved those triple gauge sets ! Had them in all my 70's & 80's cars. Those stupid idiot lights don't tell you anything ! I used to mount them under the ash tray, remember those ??? I even had a 4 gauge set that told me the trans temp ! This way I knew how far I could push it, and beat the death out of it !Most only had one driver side mirror, electric rear defrost was a treat, hand crank windows, usually with a vice grip because the handle broke, no power door locks, no alarm., no trunk opener,. One key for ignition, one key for door lock. If the headliner started sagging, just got the staple gun after it. AND, no stupid flap in the gas tank. Someone wanted to steal gas, I got a lockable gas cap. I was happy as a pig in sh-t !!!!
I don't know about you but I biy the $99 push mowers.It's your equipment do what you but your take on being cheap is severely flawed.
OIl $30 for a jug of good stuff.
replacing lawn mower $$$$
He never said anything about $99 mowersI don't know about you but I biy the $99 push mowers.
I'm always bending crank snouts finding rocks and sticks.
Last year I hit some steel tubing buried in the grass. Shot out across the yard like a 12 foot torpedo.
Dropped it off at padnos, mower and tubing, then bought a brand new one on the way home.
They're cars and trucks man. They make new ones everyday.
It doesn't get black from the heat. Have you ever measured the oil temperature in a lawnmower?If you plan on keeping those machines, used oil is not the way to go. 20 oz's / 1/2 qt tops depending on the size of the engine. Just not worth it. You'll coke the rings in no time, and it will become a burner. Cheap oil is cheap enough. At least it's new. Unless these are all trash picked machines, you're throwing money to the wind. That oil in those little engines goes black from heat in no time. Air cooled. To each his own. Not my cup o Joe though.
You can’t explain or reason with him. Which is why I gave up. He’s crazy and won’t listen. Cheap oil is better than filthy oil. You just can’t reach know it all people I tell yaOKNot gonna go back and forth on this discussion. Do as you please, and I'll do as I please. Best of luck to the both of us
How is it "filthy oil" when I oil test it and it comes back in at least fair condition besides some fuel dilution and viscosity loss?You can’t explain or reason with him. Which is why I gave up. He’s crazy and won’t listen. Cheap oil is better than filthy oil. You just can’t reach know it all people I tell ya
Doing an oil test is almost like knowing everything when it comes to used oil.Yep ...they called " IKE" ( I know everything ) Whatev........Don't care... Tomatoe / Tomattoe ----Potatoe / Potattoe
Not really.You could go to the other extreme and use Amsoil and run used oil analysis , etc. Everyone would love you and tell you what an awesome guy you are .
I do. The used oil goes in free mowers that I accumulate that don't even know if they'll start. No point in topping off a mower that turns out to be a dud with new oil I paid money for. Then once I know they run I'll dump what's in there and fill it up with more used oil, run it enough to test it out, dump it again and fill it with new oil. That way I'm only putting new oil that costs money in known good mowers.I also do not understand the reasoning behind doing this. Go buy a QT of Mobil 1 or Amsoil and run that a few years instead of puttung used oil in it .
