I have a friend that has an off road shop. He could do both axles in a 4x4 for that price.
Yup. Better work and pay less.I would definitely take it to a gear shop that does differential work only.
I put the wrong year model. It was my 1997 F150.Alan's Gearworks in Clearwater, FL rebuilt my 07 F150's 8 8 differential 3 times. It kept whining after being rebuilt. Come to find out the whole differential was twisted just a bit throwing everything out of spec. They installed one of their complete differentials and everything was fine. They only charged me for the install.
ROFLMAO--- The title of this thread struck me funny,,,I can imagine saying, " took myself to my doctor to check out that noise n my rear end,,,lol I know, Ive missed my medication today...
yes, changed out the gear oil and put Valvoline syn back in, the noise stayed the same.Have you checked the lube level? This is an expensive noise to fix. However, it will probably last quite awhile if you drive it moderately. Was it fun? I knew a guy who would blow up a rearend every Friday in his '56 Belair. He had access to a lift and air tools , so it was easy. It would be a doable back yard project. Just a lot of hard, dirty, knucklebusting work.![]()
That is crazy. I set of gears, bearing, shim kit and crush collars should be under a G total. Some of the Mustang rear ends are a bit noisy anyway, but apparently you have an actual issue.Just talked to the guy at the shop. He said the teeth on the gears are pretty well worn and he said they will only put in a reman diff. total cost around $2300 installed. I think im just going to live with the noise for a while, or pick up the one at the junkyard for $650 and get a mobile mechanic to come by my house and help me get it on.
I paid 1/2 that for new gears bearings , rebuild at east coast gear.Just talked to the guy at the shop. He said the teeth on the gears are pretty well worn and he said they will only put in a reman diff. total cost around $2300 installed. I think im just going to live with the noise for a while, or pick up the one at the junkyard for $650 and get a mobile mechanic to come by my house and help me get it on.
https://www.jasperengines.com/rear-wheel-differentialsHow do you even put a "reman diff" in an 8.8? It isn't like you can drop the pumpkin out.
Been there, done that.To get gears right without whine, isn't a job for just anybody. Had the gears changed 3 times in my ford 8.8 before it was right. $900 the first two times. wasn't charged for the second, same shop. $1200 for the third, and even then it still had a little bit of whine. New gears at every change.
