Originally Posted By: KrisZ
Originally Posted By: skyship
Car bodies do last a lot longer than they used to but modern cars have some very expensive parts that wear out some time after the warranty that are something of an issue in terms scrapping cars that could be repaired. Self levelling shocks and expensive exhaust systems are top of the list, although the ECU and other electronic boxes fitted to the new generation diesels are also very expensive to replace.
So why the crusade against thin oils then?
Canada has one of the harshest environments for car operation in the world. Yet, people that rust proof their cars, seem to have no problems getting their car into 300,000+ km ranges with the cheapest conventional oils usually in 5w30 or 5w20 grades. We also have to pass emission test every two years which I never had any problems with and most people I talk to have no problems with passing these tests either.
In Ontario the failure rate was so low that they decided to go to the OBD2 scanner tests only, to lower the costs of operating dyno machines I guess. If oil was such a big deal, it surely would show up in Canadian climate. Yet everybody just keeps on chugging along and piling on miles on their rides.
Ontario is the toughest province in the country as far as vehicle inspections too.
From what Trav just posted though he is correct that we have less fit vehicles on the road as compared to Europe. You should see the reservation vans around here. The brake pedal is for show,they stop with both feet like the flintstones.
The thick thin thing is mute when a vehicles lifespan is a decade and the body,not the engine sends it to the crusher.
If we use 10 years as the average,then in that 10 years,in North America,we use less fuel in a comparable engine over that 10 year lifespan vs a European vehicle. If the body sends it to the crusher then who cares if the engine is worn out or not,the car is a boat anchor.
So if a thin oil maintains the whole cars lifespan and uses less fuel doing it,before it gets crushed then where is the issue.
And I know from experience the scrapyard is filled with vehicles where the engine runs mint,but the car is rotted away,using thinner oil.
I am now lost as to the point of this debate. In a decade the cars are dead anyways,does the engine even matter anymore,its going to get melted down whether it runs stellar or not.
