Originally Posted By: Nickdfresh
Originally Posted By: skyship
Car bodies do last a lot longer than they used to but modern cars have some very expensive parts that wear out some time after the warranty that are something of an issue in terms scrapping cars that could be repaired. Self levelling shocks and expensive exhaust systems are top of the list, although the ECU and other electronic boxes fitted to the new generation diesels are also very expensive to replace.
Everything lasts longer on cars, including engines running 5W-20.
If you guys WANT to believe that that vehicles will somehow get more engine life using a 5W-30 than a 5W-20, go ahead. But there isn't the evidence from Australia or the UK to base this assessment on, there is much in North America to the contrary.
You're just rationalizing a largely impulsive, emotive belief with selective anecdotes and B.S...
+1. I may be the BITOG poster boy for 0-20 oils. I plan to keep both cars for an extended period of time and plan to use 20wt all the way with 10K OCIs. Thus far no need to change to 30wt.
