92saturnsl2
Thread starter
I'll be darned if that didn't fit it perfectly. The $6 Chinesium connector (it came in a pack of 3 for that price!) doesn't look nearly as durable of plastic / metal pins as the OEM briggs that mates with it; I'll have to keep an eye out for hot/yellowing plastic on that end but at least I know which connector fits.
I'm pretty close to the finish line. Engine is bolted down securely w/ grounds attached, wiring harness looks factory fresh without modifying the new Briggs harness at all. PTO/hydro pulley mated up just fine like the old. Exhaust is done and solid.
Trying to think of what's left-- I have a place for the new starter solenoid, just need to fasten it and connect the wires. Engine came with a simple plug for oil drain that would make a *terrible* mess if used that way. I need to plumb a piece of iron pipe to it w/ a 90 degree elbow & cap (for future oil changes) before I fill it w/ oil, which is how the old Kohler was configured.
Throttle cable is a mixed bag. I can make it fully functional right away using the choke lever on the mower. It extends the Briggs throttle fully and even engages the choke at the end of travel (Briggs has a single unit tied together). The actual mower throttle cable is too short, it would wrap it against an exhaust tube to reach that area. Ultimately I plan on separating the functions, but I need to buy a longer throttle cable.
