- Joined
- Dec 20, 2022
- Messages
- 640
Engine is a 20HP Briggs V-Twin Intek. Model #407677.
I brought my mower into service a few weeks ago. Changed the oil, oil filter, and air filters. Mowed my yard, ran a little rough. I checked the plugs, one looked perfect, the other one was black as can be. Swapped out the plugs, right cylinder fouled within 10 minutes, plug was not wet, just soot, running very rich. I expected the push rods on the right cylinder to be dropped based off the reputation of the engine. Took off the valve covers, both sides looked good. I then took off each head to check the head gaskets, also both good. Put it all back together, did a valve adjustment, ran well until this week. Got done mowing, looked over and saw the left cylinder had oil pouring out of the vacuum line for the fuel pump, still not having full power. Any ideas on what it can be?
