Have a 2000 New Holland LS45 riding mower (Toro Wheelhorse 268H rebadge) I put away a couple years ago, the old Kohler V-twin was shot, needs a new engine. The mower condition is such that it's worth getting going again.
Went with a Briggs; decent deal which became even better after adding coupon codes.
https://www.acmetools.com/briggs-an...n-crankshaft-44t977-0009-g1/400409000142.html
It has the correct mounting bolt pattern & shaft size which will connect w/ mower pulleys and PTO no problem. The big question mark is exhaust and electrical. Has anyone performed this type of swap between V-twin engine manufacturers? I have a hunch the old Kohler muffler won't be a direct fit and that I'm in for some electrical work. I have fabrication skills, so I doubt there's anything insurmountable.
Any input from those that have done a swap to a different manufacturer would be appreciated.
