That's not how it works. Developement starts with a more balanced mechanical
and hydraulic distribution today, much more balanced, closer to 50:50 (or say 60:40
to 70:30 to stay real) compared to yesterdays (maybe 80:20 to 90:10).
Now, while the increased braking on rear helps to prevent excessive rust on the rear
rotors, this sadly also leads to early and more often locking/ABS interventions on rear.
Not desirable. It affects stability and irritating for the driver.
Then the "ABS programming" comes into play, because every modern ABS comes with
an EBD (electronic brake distribution) feature built in. With the slightest hint of "locking"
on rear the rear channels (in the ABS/ESP module) close to to inhibit real ABS interventions.
