nthach
The squeal was from the back. Dust buildup. Took the drums off, cleaned the brakes, scuffed(and chamfered) the shoes. Lubed the contact points.I'm confused. You're original thread said you installed Advics over " turned" ROTORS. Then you had a squeak. Rear drums don't squeak. They do warp, and get dusty, and get out of adjustment. So, where is the noise coming from ? The front or back of the vehicle. ? But, meanwhile, while you have the drums off, wash down everything with brakleen, wash out the drums, take some sandpaper and take off any glaze on the drum where the shoes hit, ( don't go crazy sanding..just a light hand sanding ). Pop off the rubber grommet in the drum, line the grommet hole up to a hole in the hub where you can see the " star" adjuster. Slide the drum on. Put the lug nuts on fairly tight to center drum. Spin it. If it spins freely, it's out of adjustment. Take a flashlight and a small bent flat screwdriver and slowly turn the star.( It will only move one way). Turn the star 2 clicks. Hit the sides with a rubber mallet to set the shoes, spin again Repeat. Stop tightening star when you sense the LEAST amount of resistance of the shoes rubbing against the drum. ( You can also hear it ). Drums are supposed to self adjust when you drive in reverse and stop, but it never works. Maybe 3-4 clicks on the star is all you may need. I'm not there to see or tell. Now back to the squeaking....the front or rear ???
