It will be a fee based subscriptionI heard they're using the sound system to simulate the Hemi tick for a more realistic experience.
Good idea.Cottage industry opportunity? Liquid cooled, high efficiency toolbox genset capable of stage 2, with some code that supports as-rolling operation? Buy your short range BEV pickup, spend 3k on this, voilá. bonus points for diesel.
Well, you are not wrong. I've been thinking the same thing. Those grid power storage system battery fires are quite something!Breaux - That semi will make a fire seen from space
YupWell, you are not wrong. I've been thinking the same thing. Those grid power storage system battery fires are quite something!
Why not simply make it a plug in hybrid, (with a big battery) with all the benefits of MPG improvements of a hybrid and electric drive?
The "cordless Tesla" was a very interesting experiment. For those who have not looked at this experiment, it was simply a small, high voltage, 10,000 watt generator mounted in back, (about 13.4HP worth of electrical power) that directly provided power to the battery pack. Not enough power to maintain battery charge on the highway, but could run all night and recharge the battery. What's interesting is just how horrible the MPG's were.
I've said it many times, but the stack of losses involved in EV's does not lead to 105mpg-e. It leads 14 mpg. The idea that an engine driving a generator, through a charge controller, charging a battery, discharging a battery, running through a motor controller, driving a motor is somehow efficient, is utter nonsense. Directly driving a wheel with an efficient modern engine is always more efficient. This is why Honda Hybrids DIRECTLY couple the engine to the wheels at highway speeds.
Fast forward to 14:56 for MPG/efficiency numbers.
Those i3 cars were everywhere around here, I can tell you that much. While it is not for me, owners loved 'em.BMW i3 was a clown car sold by a Luxury car maker. They purposefully pulled a Toyota Prius move making it look like a dork mobile . It failed epically as it should have .
Good for RAM. They sell enough of ICE to dabble in EV market and keep feet in both places. I think best move is dabbling in EV is best move for auto makers.
I have evidence that electricity isn’t the answer. It’s published by the EPA but nobody mentions it. Read this:
https://www.epa.gov/eps-partnership/sulfur-hexafluoride-sf6-basics
Again, I still don’t understand why PHEV or “range extender” models haven’t pursued a smaller, maybe 3 cyl turbodiesel that could literally be made a match in heaven for efficiency. Designed from the ground up, one could determine the charging load required and the alternator/generator size needed so that when the TD kicked on, it would always run at a constant speed that also happened to coincide with peak (minimum) BSFC. Considering it would be at steady-state RPM, it would also be insanely easy to size the turbo for optimum efficiency as well. That means for periodic top-ups it would turn on, charge, and turn off; but if the battery were nearly fully depleted the PHEV would essentially mimic the operation of a diesel locomotive which would then run continuously (maybe at a slightly reduced max output) for the remainder of the diesel tank range but the vehicle propulsion would remain wholly electric, so no engine/motor/gearbox sandwiches necessary.As you may or may not know, Ram has confirmed an EV truck, but today they’ve announced it will have a range extender as well. I think it’s a great idea. They even opened up a thing where you can sign up and give them your thoughts and opinions on what the EV Ram should have/do/whatever.
Devils advocate: it’ll be some enormous range extender that can power a city block, because Ram. Also probably Hellcat engine.
Ram Electric Pickup Will Have a Combustion Range Extender: CEO
Is an onboard gas or diesel generator the solution to electric pickup range anxiety?www.thedrive.com
I agree. Edison Motors is doing that for vocational trucks up in Canada… though they’re using a CAT C9 for the diesel-electric models.Again, I still don’t understand why PHEV or “range extender” models haven’t pursued a smaller, maybe 3 cyl turbodiesel that could literally be made a match in heaven for efficiency. Designed from the ground up, one could determine the charging load required and the alternator/generator size needed so that when the TD kicked on, it would always run at a constant speed that also happened to coincide with peak (minimum) BSFC. Considering it would be at steady-state RPM, it would also be insanely easy to size the turbo for optimum efficiency as well. That means for periodic top-ups it would turn on, charge, and turn off; but if the battery were nearly fully depleted the PHEV would essentially mimic the operation of a diesel locomotive which would then run continuously (maybe at a slightly reduced max output) for the remainder of the diesel tank range but the vehicle propulsion would remain wholly electric, so no engine/motor/gearbox sandwiches necessary.
Considering Kohler can make 1.1L 3cyl TDs that pass emissions with SCR, I fail to see why there’s not more done on this front.
A friend of mine had one; I'm 6'4", 36" inseam, 35" sleeves, and 15 shoes. There wasn't a shoehorn sturdy enough to get me in.Those i3 cars were everywhere around here, I can tell you that much. While it is not for me, owners loved 'em.
Takes 10 minutes to add 100 miles of range, at best. What a turd. Can add 400 miles of range to my ICE stuff in 5 mins. Don't see how these will work for road trips, or towing. I would have expected a breakthrough given how they hyped it up and bragged about taking people's feedback into consideration for building the "ultimate" truck. It's less functional than any Ram you can buy today. Plus, can't wait to see how the doors shut without the B pillar after the typical Ram rust sets in after 5 years.Lame, still just a concept vehicle - basically nothing for specs
Press release:
Ram 1500 Revolution Battery-electric Vehicle (BEV) Concept Unveiled at CES 2023
The Ram Revolution BEV Concept is a visionary road map showing how the industry’s leading truck brand will redefine the pickupwww.stellantis.com
It's not a turd as it doesnt exist. CONCEPTTakes 10 minutes to add 100 miles of range, at best. What a turd. Can add 400 miles of range to my ICE stuff in 5 mins. Don't see how these will work for road trips, or towing. I would have expected a breakthrough given how they hyped it up and bragged about taking people's feedback into consideration for building the "ultimate" truck. It's less functional than any Ram you can buy today. Plus, can't wait to see how the doors shut without the B pillar after the typical Ram rust sets in after 5 years.
