Mods I am considering...
Changing to a 4.10 rear end...this is my highest priority mod for AutoX. 1st is too low, and 2nd is too high, I think this would make the car much more engaging to drive on the street as well. With a 0.5:1 6th gear, it will still be plenty tall enough for good highway mileage.
Increase compression ratio...considering milling the heads 0.040" - that should bring me to about 11.1-11.2:1. I always run 93 octane...and have seen reports of many folks streeting this high of a ratio...thoughts? (head cleaning, crack check and valve job brings it to ~$400 total at a very reputable shop).
Considering going to full roller rocker arms and increased ratio to 1.8:1...should increase lift and duration of the stock cam.
-Will the combo of milled heads and slightly more lift cause piston/Valve interference if I keep the stock cam?
Engine has ~100k miles, and purrs like a kitty. Burns or leaks zero fluids. All stock internals AFAIK
Thoughts?
-I am NOT changing the cam...I want to keep that stock.
-I am NOT going forced induction for now...or most likely ever. I already have long tube headers and CAI.
-These seem to be really good choices for a low budget boost in hp and driving fun.
-New heads are most likely out of budget...but could I get new heads that would out perform the increase in CR and rocker arm combo for just a small $$$ increase? (new heads, but no spending on rocker arms, and head machining)
-I have no desire to raise the redline...would like good power below 6k rpm
Thoughts?
