Questions about Castrol's MSDS info
slo town
$200 Site Donor 2026
The Willow Creek District AVA
Hello:
I've recently begun stocking my garage with German Castrol. I have long used Pentospeed 0w30 VS but that's getting hard to find because it's no longer produced.
Anyway, I was snooping around Castrol's MSDS info and see things that I do not understand. Perhaps someone can explain some things to me.
Info below organized as follows"
Oil Type / Description / CAS # / Percent Composition
0W-30 Syntec with SPT (GC) / Base oil - highly refined / Varies / 15%-20%
5W-40 Syntec with SPT / Base oil - highly refined / Varies / 85%-90%
10W-60 RS / Base oil - highly refined / Varies / 20%-25%
5W-20 Syntec with SPT / Base oil - highly refined / Varies / 85%-90%
Can someone explain to me how the composition percentages vary so much? Am I to conclude that the 0w30 German Castrol contains more PAO and/or esters than does the 5W-40?
Great site. Great information sharing. Thanks in advance,
Scott
MSDS stands for Material Safety Data Sheet, which outlines chemicals that are of interests to health/medical personnel when someone had reactions with it (e.g. ingestion, consumption, allergic reaction, etc.) to aid with the medical diagnosis and treatment.
MSDS does not list the composition of the chemicals used in the product, nor the specifics of any of them.
With that in-mind, you shouldn't use MSDS as a form to gauge the oil's composition.
Q.
Yes. At least that has long been the understanding here, GC is GPIV based where the rest of the Syntec line is GPIII based.
Q.
Not sure what you mean by this. MSDS states the hazardous chemicals contained in a material, only "chemicals that are of interest to health/medical when someone had reactions with" is not true. If a chemical is deemed hazardous it is listed on the msds.
It also DOES list the composition of the hazardous chemicals of a material in a % or ppm, or some type of measurement.
You can use a msds to gauge the composition of the base oil to a point if you have the CAS number and what base oils are classified under that.
BP has the HTHS # incorrect on the GC the last I looked at the TDS. Notice the PP on the GC. indicating a possoble high synthteic base content to help meet the long approval list for this lube. PP is not reliable but they typ only crypticly list < max spec for ccs and mrv.
Group 3 is "base oil highly refined". The MSDS you mentioned reinforces the mantra that 0w-x oils are generally comprised of Gr4/5 whereas the 5w-x generally have more Gr3 unless otherwise noted.
cp3 and BMWTurboDzl, thanks for your direct answers to my questions. This was what I was thinking but I wanted to verify it with you folks.
To All, thanks for your replies. Each has been helpful as well.
Scott
