If you use this mount, I believe it comes with a restrictor (maybe not). NAPA lists it for $19.95, IIRC.
24755
UPC Number: 765809247550
Principal Application: By-Pass Filter Base to Add Spin-on By-Pass Filter on Small Gas and Diesel Engines. (51050, 51051 or 51320 May be Used)
All Applications
Style: Filter Mounting Base
Service:
Note: Lube Filter Conversion Kits By-Pass Filter For Small Gas And Diesel Engines
Large Gas and Diesel engine equipped with cartridge type by-pass filters can be converted to the convenience of a spin-on with this kit. The kit may also be used to add-on supplemental by-pass filtration to provide increased engine protection. A choice of three different sized filters are available.
PART NUMBER: OB1305
Descriptions : By-Pass Lube Filter Base
Use_With : B50, B164, BT341
Contains : Threaded Stud 5/8-18
O.D. : 4 1/4 (108.0)
Inlet : 1/8 In. NPT
Outlet : 1/8 In. NPT
Length : 2 3/4 (69.9)
The B50 from Baldwin says that the filter contains a flow control orifice:
PART NUMBER: B50
Descriptions : Microlite By-Pass Lube Spin-on
Notes : Can be used with OB1305 base.
Contains : Flow Control Orifice
Fits : Allis Chalmers, Caterpillar Engines; Jeep Light-Duty Trucks; Massey Ferguson, Oliver Equipment
Replaces : Allis Chalmers 4512207-3; Caterpillar 666-3172; Chrysler J0936407; Massey Ferguson 1069954-M91
Thread : 5/8-18
O.D. : 3 11/16 (93.7)
Length : 5 3/8 (136.5)
I.Gskt : G381-A
Related to : B164 (Long Version)
BT341 (Short Version)
but the Wix equivalent, doesn't mention this:
51050
UPC Number: 765809510500
Principal Application: Allis-Chalmers, Fiat, Continental, GM, Hyster, Isuzu, Iveco, Towmotor, Other
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: By-Pass
Media: Paper
Height: 5.178
Outer Diameter Top: 3.660
Outer Diameter Bottom: Closed
Thread Size: 5/8-18
By-Pass Valve Setting-PSI: None
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.834 2.462 0.200
btw- just due to typical Fram quality ..I'd highly recommend visiting NAPA next time for your bypass filter needs.
