Originally Posted by Jay1981
Yes, there were some below zero starts.
I'm new to cartridge filters however. I'm just curious, what do below zero starts have to do with the filter failing?
I really don't know how this type of system works, or if there is any sort of bypass.
When it's below zero the oil is very thick, which causes a lot of delta-pressure across the filter. At that temperature you can bet the filter bypass valve was opening. Without a filter bypass valve a filter could be destroyed in a cold start situation.
It's possible the filter bypass valve malfunctioned, but it's more likely the media could not take the max delta-p that the bypass valve regulated/allowed across the filter.
