- Joined
- Jul 22, 2022
- Messages
- 526
Not trying to be a pessimist. Give that oil a couple thousand miles then report back.Same filter for 2 oci’s!
Didn’t even change it for this change
You laugh at Rogie for he hears voices in his head.
Mine keeps telling me to buy a geo metro and put a big turbo and methanol on itI sometimes hear voices in my head.
Beware! The Kia Boyz parents may have been past-Gen Geo Boyz'.Mine keeps telling me to buy a geo metro and put a big turbo and methanol on it
If I had a Time Machine I’d buy one in a New York minute. You know a small turbo is not a half bad idea. A small Hitachi or Honeywell “Garrett” would do. That size car would be sweet 125-135hp/150ft lbs of torque. 6spd manualMine keeps telling me to buy a geo metro and put a big turbo and methanol on it
Leave it, let it get worse and die, then they get to sell you a new car. That's normal right?. They don't want you driving a car forever, kills repeat business. My conspiracy anywaysIf it's chain rattle I don't see where that could be considered normal.
Have a 2016 GS350 with the 2GR-FKS engine. 52,000 miles, bought used with 28,000 miles in 2019 car was serviced at dealer prior to my purchase so prob M1 was used. Observations on the recommended 0W20 .. I change at 4000 miles (cost, a few hundred per year extra is not going to bankrupt me) ... Amsoil, very smooth, quite but seems to reduce engine response and HP, M1 (as sold by Lexus, API SP) with the Toyota ad pac, top end is noisy but HP and throttle response are very good. Penzoil Ultra Plat .. very quite (top end noise reduced by at least half, way smoother on idle than Lexus M1 and more throttle response and HP (311) is restored. PUP in this engine is golden.Hey all got a 2.5l 2ar-fe in my vehicle and it had that bad startup rattle that Toyota says is normal. It would go away within 1-2 seconds and hasn’t effected anything. Originally was running 0w20 so I went to m1 afe 0w30 and I still had it. It may have slightly reduced with 0w30 compared to the 0w20 but it was still prominent.
So this oil change I found ultra platinum 5w30 on sale and decided to try it out. It’s been 3 days in a row and haven’t had any \ very minimal startup rattle. I honestly think pup 5w30 is perfect for this engine as something about the formula makes the rattle practically non existent.
Any ideas ? Or has anyone experienced similar effects?
oops .. meant quiet .. not quiteHave a 2016 GS350 with the 2GR-FKS engine. 52,000 miles, bought used with 28,000 miles in 2019 car was serviced at dealer prior to my purchase so prob M1 was used. Observations on the recommended 0W20 .. I change at 4000 miles (cost, a few hundred per year extra is not going to bankrupt me) ... Amsoil, very smooth, quite but seems to reduce engine response and HP, M1 (as sold by Lexus, API SP) with the Toyota ad pac, top end is noisy but HP and throttle response are very good. Penzoil Ultra Plat .. very quite (top end noise reduced by at least half, way smoother on idle than Lexus M1 and more throttle response and HP (311) is restored. PUP in this engine is golden.
Oil drains out of the passageways etc when the engine is not running.Does that engine have a VVT-i setup on it?
Edit: So I looked it up and it does have the VVT-i setup. On my 1ZZFE, it has it also and I also get a rattle at startup that dissipates after 1 second…….tried everything and the issue continues. I also was told that it is normal (?)…….time will tell.
excited for u to hear backSame Ownership Company, but not the same add-packs and base oils. Glad to read things are quiet under the hood.
I'm working on our Kia returning to engine quietness. Valvoline and Pennzoil kept things a little quieter than how it sounds currently..... like a sewing machine.
Trying new brands and viscosities is constant. Next-up is Castrol Edge Euro, then HPL No VII 10w30..
Running PUP 5w-20 in my 2.5. Very quiet and smooth.a little over a month in and wow oh wow this 5w30 pennzoil ultra platinum is the quietness king
made the vvt non existent even tho others have mistaklenly said that oils can never make a rattle go away and that me trying to find an oil to mitigate the issue was equal to trying to find a needle in a haystack
im telling u, any toyota 2.5l 2ar-fe users, try this 5w30 from PUP. not any other brand, i tried m1 and it wasnt quiet. but this PUP makes the engine sound normal at startup
