Vehicle is a 2007 Toyota 4Runner at 274K miles, bought at 164K miles with negligent maintenance by the original owner. I had initially flushed the black PS with Castrol DEX-MERC High Mileage ATF, temporarily plumbed in a Magnefine filter on the return hose for a few hundred local miles while the crud pushed out, and all seemed fine until temps dropped into the <40degF, it would make a groaning sound on cold startup until the fluid warmed. Ran that for ~50K miles with no improvement, then flushed with Valvoline DEX-MERC and same noise at cold temps.
This summer I saw a video by the Car Care Nut, who appears credible and claims to be a Toyota Master Tech. In the video, he asserted that power steering fluid was to be used rather than ATF (skip to 13:40):
I bought two quarts of Lube Gard "Complete Synthetic Power Steering Fluid Multi-Vehicle Formula" and did another flush. The fluid is clear in color and I didn't get every last drop of the ATF out, as the fluid in the reservoir turned light pink shortly after reconnecting the return hose and starting the engine. Ah well. The good news is the cold start groaning noise is gone, even down to 1degF recently. The steering has always been smooth and this made no noticeable improvement, but it's nice not hearing the "morning sickness".
