Same here, 3 or 4 sets of pads on HD truck rotors no issues.I replace rotors when they reach the minimum stated thickness and they'll go though several sets of pads before that happens. I see no reason to replace them prematurely just because.
Same. Never had an issue doing this.I usually just spray the old rotor with brake cleaner, give it a few scrubs with emery paper, then throw the pads on. If your rotors are warped, nothing besides resurfacing will help.,,,
It was common practice to resurface rotors and brake drums years ago. It worked then and should work now. If you don't have the right tools to do it, or don't know how, I can see it being a problem.,,Resurfacing won't un-warp warped rotors... been there, tried that...
how much does that cost?Properly resurfacing rotors will correct DTV and lateral runout issues. Every time.
I guess maybe I should go in the back and lean over my machine shop guy's shoulder to tell him how to do it? Or do you think true BITOGers should have a brake lathe at home so they can do it properly? I'm just saying most of the machine shop guys in my town are true salt-of-the-earth fellas who are that perfect combination of not highly paid nor highly trained.Properly resurfacing rotors will correct DTV and lateral runout issues. Every time.
It has always worked for resurfacing rotors to remove minor ridges and the brake material from the previous set of pads, but you can't bend a rotor back to true with a lathe.It was common practice to resurface rotors and brake drums years ago. It worked then and should work now. If you don't have the right tools to do it, or don't know how, I can see it being a problem.,,
I see FB market place advertise for $30 per rotor in my area. A new rotor for my car is about $30.how much does that cost?
Yesterday I noticed the mammoth rotors on the outlaws new F Sport, I don't think I'll be replacing those any time soon. Toyota has finally begun listening to @edyvwI have never seen a factory service manual specify the procedure you're describing. Smoother is generally better for pads, most ceramic pads have minimal ability to cut thru a rough surface finish.
I was hinting at using an on-car brake lathe.I guess maybe I should go in the back and lean over my machine shop guy's shoulder to tell him how to do it? Or do you think true BITOGers should have a brake lathe at home so they can do it properly? I'm just saying most of the machine shop guys in my town are true salt-of-the-earth fellas who are that perfect combination of not highly paid nor highly trained.
How would that remove warp any better than an off-car lathe? It seems like the technician needs to check runout and if it can be machined back to true/flat without being brought below the minimum thickness, it could be done on either machine.I was hinting at using an on-car brake lathe.
