Premature aftermarket timing chain failure
I don't know if this is the case for timing chain sets, but other chain/sprocket drive systems I've dealt with require you to replace the sprockets together with the chain, otherwise, the slightly worn sprocket won't properly distribute the load on a new chain, causing premature wear.
Originally Posted by chipdipjones
did oil change due to metallic sheen in oil.
I'd do more than one oil change, in rapid succession. Consider a magnetic drain plug. Grit, carbon particulates and especially steel particulates will accelerate wear markedly.
