I'm about 500 miles into my second run of PP on my Buick. I checked it today and I added over 1/4 quart. That would put me at 1 quart per 1500-2000 miles (my first run of PP used 1 quart in under 1500 miles), instead of the 1 quart per 3000-3500 miles that it's used on Motorcraft, M1, and Napa Syn. I like PP, but if it's going to use this much, I'm rethinking my choice. I'd like to stay with a synthetic because of the winter cold. GM specs a 5w30 at all temperatures. I'm not interested in extended drains (will follow OLM at the most). I'm not sure of the maintenance history before I bought it about 10k ago, but I'd guess conventional changed often, based on the cleanliness of what I can see through the fill tube. So, I'm thinking about going back to either Motorcraft blend or Napa Syn/Valvoline Synpower but would consider Maxlife or Mobil 1 high mileage (the new SN), what would you recommend? (I had just decided on PP... now my choice is harder) So, what do you all think? I wanted to give PP a chance, but it's drinking it this OCI too. Thanks.
