Potential X300 OC
Ohio
I have a 2007 JD X300 with a Kawasaki w/ approx. 125 hours on it.
Since new, I have been doing yearly OCI's using only JD TurfGard 10W30 with JD filters.
I am contemplating changing to Citgo 10w30 full synthetic because I stumbled across a couple of cases for .49/qt.
Any experiences with running a full synthetic in the Kawasaki?
Citgo syn 10W30 for 0.49/quart is a steal. Use it with confidence.
After that is used up, try a 15W40. Kawasaki engines live 15W40 oil, and seem to use less than when using a 30 weight.
All X300's have the K46.
It is fine for what I use it for but I dislike the fact that it is not a serviceable transmission without basically removing it from the tractor.
If it had of been an option at the time, I would have bought the X310.
