Originally Posted By: Kestas
I am presently working on an issue of crankshaft roller bearings in a small 10 HP engine that fail after a certain while. Basically, the client is trying to take a homeowner application and make it into a commercial application by upping the run time requirements.
The upshot of the failure is that the 10w30 lube used for the engine can't handle the high temperatures (~150°C) and what we are seeing is a lube failure. Fo some unknown reason, the client refuses to specify a heavier weight for this application.
Be careful with the lighter weight oils in an engine that has no cooling.
If it is a 50 hour rated engine and being used in a commercial application, the owner must be mental! You get what you pay for and buying homeowner equipment to be used as heavy duty commercial will give you a failure every time. Sell them a real commercial Kohler Command or Kawasaki Kai.
