post your latest transmission lubricant change.
1999 Cavalier 3-speed (183k)
Out: Supertech Dex/Merc
In: Supertech Dex/Merc
Welded in a drain plug so this process will be a lot less messy next time
2000 Ford Explorer V6 4WD (5R55E auto)
Out: Roughly 2:1 mix of whatever Meineke put in when they flushed it; and Mag-1 full synthetic ATF
In: Castrol Transmax Mercon V + Magnefine inline filter
2002 Ford Crown Vic PI 159k 4R70W
Out: Unknown.
In: 1st time: 9.5qts Kendall Mercon V + Magnefine
2nd time: 3.5qts Recovered fluid, 2.5qts Kendall, 3.5qts Castrol Transmax Mercon V.
Screwed up the JMod the first time around so I bought another 6qts of fluid, recovered what I could from the cooler line and redid it.
Maxlife ATF. Sucked out 6 quarts out of the Jaguar XJS and replaced with Maxlife. In a few weeks I'll do it again and maybe then add some Lubegard Red.
06 Cadillac Escalade EXT
tranny: Supertech Dex VI
transfer case: Valv Maxlife full Syn Dex III compatible
front & rear diff: Valvoline 75W90 full syn
V70
Out: Dealer supplied BG flush 50,000 mile OCI
In: Mobil 3309, 13 quarts
Method: IPD drain and fill
Will change to 25k OCI
