Post your latest small engine oil change
1995 JD LX178 with Kawasaki FD440V Liquid Cooled Engine
Hours: 717
Out: Shell Rotella Gas Truck 5w30 and Fram XG4967 filter
In: Pennzoil Euro L 5w30 and Fram XG4967 filter
About 35 hours since last change in 2021. Need to get in the habit of annual changes :).
35 hours is perfectly fine on the oil and filter you are using. Most manufacturers recommend 50 hours on the oil and 100 on the filter.
I picked up this franken mower today, it's a 2019 MTD made Craftsman FWD deck, but it's got a 90s? vintage Quantum with a manual throttle on it, the starter/blower housing says it was manufactured in 2011, but the 4HP Quantum Power cover is very late 80s-1990s style so is metal throttle level and metal flex conduit used for the throttle cable. They were throwing it out because it was leaking fuel because the fuel line was super rotted, the air filter is absolutely plugged, and I need to replace the primer bulb, but it ran OK which I took the filter off and ran it on starter fluid, so I replaced the fuel line and changed the oil, Tomorrow I guess I'll scrape the grass chunks out of the deck and give it a test.
Out:??? not quite enough of it pretty black, but about the viscosity I'd expect 40-50F SAE30 to be.
IN; 15w40 Rotella T4.
Husqvarna LC221a w/ B&S self-propelled AWD mower from Lowe's, I had to work on the terrible drive system they used but got it working again and decided to change the oil using the mityvac syringe extractor.
Out: Chevron Delo XLE 10w30
In: Same
In: Same
I hate those AWD Husqvarna's, I don't know what moron designed the belt guards, but they don't actually protect anything , in fact they just seem to steal lift from bagging and mulching and direct the clippings right along the belt and mat it into the transmissions, also the idler pulleys get destroyed every few seasons since they're not protected at all.
2019 Craftsman 26" snowblower 243cc PowerMore engine. Bought this unit brand new, and even though it's an MTD product its served me well and has done anything I've ever asked of it. Some winters been much more asking than others! Oil gets changed every spring whether it needs it or not.
Out: Mobil 1 0W30
In: 0.6L Mobil 1 0W30
2022 Toro Power Clear 518 ZE single stage snowblower - New this past winter. Ran the factory Toro 5W30 for a few snowblowing driveway sessions. Then changed for a full synthetic oil for the remainder of the winter. This one gets whatever 5W30 full synthetic I have left over from my vehicles, will change every spring.
Out: Valvoline Advanced Full Synthetic 5W30
In: 350ml Valvoline Advanced Full Synthetic 5W30
Craftsman riding mower with 22 HP Briggs twin cylinder
377 hours
Out: Mobil Delvac 15w40
Off: Briggs oil filter
In: Mobil Delvac 15w40
On: Fram FE3614
Also changed spark plugs, greased spindles, bearings, and steering knuckles
Kohler 25 HP V twin installed on the GT5000
Out: about 2 qts of Synthetic 10W30 H/M with oem Kohler Pro oil filter
In: VP Full synthetic small engine 4 cycle 10W30/SAE30 oil with a Purolator L10241 filter
Husqvarna all wheel drive Briggs & Stratton 6.75 HP lawn mower
Out: Synthetic 10W30 H/M
In: VP full synthetic small engine 4 cycle 10W30/SAE30 oil
Craftsman Briggs & Stratton 6.5HP 3200 PSI power washer
Oil used:
I have a spare Predator 212 from an idea that went horribly wrong. I ended up changing the oil in that with Mobil 1 0w40 and swapping it with the Honda GC from my log splitter just because. Cold starts this winter will be interesting.
I also have a little Simpson pressure washer with a generic 210cc engine that received a mix of T6 5w40 and Mobil 1 0w40.
