Post your latest small engine oil change
Latest would be last Fall. That big old Generac 5500 Chonda had its Valvoline VR1 10W30 Synthetic dumped after 10+ years (!) and some Valvoline 5W40 Euro that had on clearance at WM.
Before you go freaky - There was likely no more than 20 hours runtime on that 10 year old oil. It even had an ounce of LubriMOly MoS2 in it. Thinking is: No Filter = No Problem with the moly sludge and particulate can only help on a dipper and splash engine.
Generac is good stuff.
2009/10 Ariens 24 deluxe snowblower Briggs and Stratton 1150 ohv, drained unknown black stuff and flushed with cheap 5w30 conventional and 30+ hours draining. Refilled with m1 0w40 fs.
Just bought a 2002 JD LX266 riding lawnmower w 16HP Kohler today with 960hrs. Has bagger and mulching kit also.
PO said oil was changed recently, oil looked a little dark but filter was covered in a layer of dirt, so changed both. Will change again in 40hours, then do 100hr intervals or every Spring more than likely.
In: 1qt 20oz of QSFS HM 5w30, 3oz Rislone and 6oz PUP 0w40. JD AM125424c oil filter.
Siphoned out as much trans oil as I could out of the reservoir and refilled w 12oz of QSFS HM 5w30. JD manual calls for 5w30 in trans, will run it for a few mows and redo it as old oil was pretty dark and a couple oz low.
Now to air up the tires, make sure deck is level - appears it at first few passes in yard, sharpen blades, and mow.
First change on CC XT1 (LT42) with Kohler 5400 (19.5 HP)
4 hours on unit - white bucket showed little metal so went to yearly service … (had cheaper options)
Sounds like he lied.
  • Like
Reactions: wlk
Did most of the spring oil changes on OPE at work today.
1st:
Scag Freedom Z with a Kohler 7000.
306 hrs on the engine, 54 hrs on this oci.
Out: 2 qts. Kohler 10w-30 syn blend and a Kohler 12 050 01 filter
In: 2 qts. Kohler 10w-40 and a Kohler 52 050 02S filter
2nd:
John Deere L111 with a 20hp Briggs Intek. Unknown hours on OCI.
Out: 2 qts. Rotella T6 5w-40 and a JD filter
In: 2 qts. Kohler 10w-40 and a Briggs filter
3rd:
Champion 2k watt generator. Unknown hours and OCI.
Out: Unknown oil (break-in oil that came with it)
In: 12 oz of Kohler 10w-40
4th:
Simpson pressure washer with a Honda GX170. Probably 15-20 hours on OCI.
Out: Unknown oil
In: 13 oz of Kohler 10w-40
