Post your latest small engine oil change
[Linked Image]
The 3 front Toro's (the last SR4 is my personal mower). All were free curb pick ups. Mostly carb tune ups and busted belts / cables. 2 fwd models, 1 older SR4 with a B&S external oil filter. Kinda cool machine.
Out: unknown
In: Supertech 5w30 synthetic into all of them.
1995 MTD Tecumseh 10hp Snowblower:
Out: B&S 5w30 synthetic.
In: Frankenmix of whatever 5w30 I had laying around my garage just to get the old oil out for storage
2006 Craftsman 22 inch mower with 6.75 hp B&S - Out: Master Mechanic SAE 30
In: B&S SAE 30
Cub Cadet XT1 42 inch Riding Mower with 18 hp Kohler Courage
Out: Cub Cadet labeled 10w30 and Kohler oil filter
In: Supertech High Mileage Full Synthetic 10w30 and Motorcraft FL910S filter
Troybilt 4 cycle Weed Trimmer
Out: B&S SAE30
In: B&S SAE 30
Champion 5500 Watt generator with Chonda engine
Out: Mobil 1 Advanced 5w30
In: Mobil 1 Advanced 5w30
Craftsman pressure washer with 5.5hp Honda GCV160
Out: B&S SAE30
In: B&S SAE30
20 year old Briggs and Stratton push mower:
Out - STP SAE 30
In - Time to empty some leftover quarts of oil in my garage. What's on hand? It ended up being about a 50/50 mix of leftover STP SAE 30 and Pennzoil 5w30. Will add Pennzoil 5w30 as needed until winter.
15 year old Murray riding mower, with Briggs and Stratton engine:
Out: STP SAE 30
In: Valvoline Premium Blue 15w40 I had enough leftover oil from the oil change yesterday on my Benz to to bring it exactly to the full line. I love it when a plan comes together!
2008 Husqvarna 20 hp Kohler Courage
596 hours
Out:
Mobil 1 Extended Performance 10w30/Castrol Edge HM 10w40
Supertech ST3614 filter
In:
Fram PH3614
This is exactly how I do it. I have an old quart bottle that I drain all of my car oil changes into. Once that hits the right level, the mower gets and oil change. Generally it's a mix of Valvoline High Mileage and Valvoline full synthetic.
Changed the original fill in my Briggs 13.5 hp in a 38" Murray. Don't laugh, it is great in my small yard with obstacles.
Put in 1.5 qts Valvoline Maxlife 10w30 Full Synthetic that I have had forever. This engine has no filter. SN rated Very low NOACK of 6 or so IIRC
Mower used no oil during break in. Oil came out greenish gray. Very full of break in stuff.
Honda HRX217 with 190cc engine
Out : Mobil 1 5W30
In : Castrol Magnatec 5W30
*While I have no issues with Mobil 1 5W30 , I thought I would try the Castrol Magnatec 5W30 - if it "clings" to metal parts in a vehicle engine - then it should do the same in a lawn mower engine .
17kw Generac generator...propane run OHVi, 992cc engine.
Out/off: Castrol EDGE Extended Performance 5w30/Generac filter
In/on: Rotella Multi Vehicle 5w30/Generac filter.
Craftsman 22" high wheel mower - 6.75HP Tecumseh
Out: oil that smelled strongly of fuel (replaced needle and seat in the carb for customer)
In: Napa synthetic 10w30
Yamaha Diesel generator - 3 cyl Kubota diesel
Out: Bulk 15w40, Napa 21064
In: Rotella T5 10w30, Wix 51064
1988 Coleman PowerMate 4000 watt generator - 8hp Briggs flat head
Out: Rotella 5w40
In: 30oz Rotella T5 10w30, 14oz Napa Synthetic 10w30
22" poulan
Who knows what came out of it - mower came with the house.
short work with a mityvac.
straight 30 back in...
UD
X320 john Deere 22 hp Kawasaki engine. Just the filter this time because the oil is only 10 hours old, but the filter 3 years old. Fram XG 3600 plus half a quart of 20W50 castrol MC.
Two Hi-Run 16 x 6.5 x 8 tires on wheels on the front. It's easier than changing out the tires and tubes, and about the same price.
63 hours in 7 years.
Toro super recycler B$S engine., 10 hours first change
Out Toro brand 30 wt
In Mobil 1 High Mileage 10w30
Love the mower easy to start, cuts good and easy to use personal pace.
The buts...hate flipping to change oil and the gasoline overfill going into air filter.
