Post your latest small engine oil change
Honda HRX217VKA (GCV190) - 345 hours
Kawasaki FR-651V (Big Dog Alpha Z-turn) - 298.5 Hours
Out - Harvest King (Rural King) 15w40
In - Same as above
Kawasaki Oil Filter - Fram 3614 out, and same in.
Cub Cadet 23 HP 726cc Kawasaki FR691V series twin-cylinder OHV engine
Out- Mobil 1 5w30
In- 50/50 blend Mobil 1 0w-40 and 15w-50
Found out I wasn't including enough ZDDP and also Kawasaki recommends heavier oils for higher ambient temps.
OEM filter 49065-7007
Curb throw away Delta pressure washer with a Honda GCV160.
Out : unknown. Was dark, but I've seen worse.
In: Rotella Gas Truck 5w30 from the Autozone clearance hoard
Realigned the choke arm into the correct carb lever hole. Drained out all the old smelly gas. Bled the carb of gas also. Started right up and pump doesn't leak.
[Linked Image]
Just did another change on my cheapo Troybilt 29cc tb590ec trimmer. Out was Duron SHP 10W30 and the same went in.
On a side note, that little cheapo trimmer starts second or third pull when cold and does not miss a beat .
2020 Toro Titan, 24.5hp, 60" deck
5hrs on it
Out: OEM fill, OEM filter
In: Supertech 10w30 Conventional, OEM filter
Breaking it in
Roughly 2.5qt capacity, Nice!
[Linked Image]
Craftsman YTS4000 with Briggs 24 HP Twin and Craftsman LT2500 with Briggs 19.5 Single
Out: Chevron Delo 400 XLE 10w30 Syn Blend and MC FL-910S
In: Mobil Delvac Extreme 15w40 Syn and MC FL-910S
Also new air filters for both.
Cub Cadet XT3 GSE with a Kohler Command Pro CH680.
The dealer changed the factory fill out with 1hr on the clock when I bought it last month as it had been sitting in their showroom for quite a while, so this was still break-in time for the engine.
Out: Kohler 10W-40 syn blend and Kohler Pro Performance filter with 16 hrs.
In: Kohler 10W-40 and Kohler Pro filter
Toro timemaster. B&S 223cc
Out : 2.5 hrs Toro factory fill Sae 30wt
In : Shell Rotella Gas Truck 5w30
Did the inaugural oil change on my husqvarna drt900. Out was what ever unknown oil and I went Pennzoil Conventional 5w30.
She was pretty dark and had the nice metallic break in.
Eagle TT90GE air compressor: Honda GX270 out-whatever black crap was in it, in-Mystik JT8 15w50 that I picked up on sale. Compressor out-very little oil, in-Oreillys Pure Guard ND30. Bought it used cheap and appears to be more than well used. Went thick on the engine oil as it will be used in the summer in 100+ degrees in the back of my truck with little airflow. Figured it couldn’t hurt.
5.5 hours on a First fill (new Inverter B&S generator) New oil is Pennzoil Platinum 5w30 and will run under 1/4 to full load for another 5 hours+ to finish break-in and then 5w30 PP. Ed
Drain plug removal on a Tecumsa (sp?) 6.5hp on a Toro mower.
Black stuff out. Overfilled with Walmart ST 30W. I will correct that.
NOTE: Read the back of the dipstick
This can be a place to post our latest small engine oil change. I guess spring time would be the best time to start a thread like this.
I figure it would be good to include the engine info, brand and weight of oil, and filter where applicable. Here goes mine:
1954 B&S 2.5HP 6B-HS - 20oz. Mobil 1 15w40 Gold Cap
Lawn mower , at the first of the season .
This week
Kohler 20hp courage single, valvoline sae30 in, super tech filter 170hrs, unknown drain
Briggs 20hp twin T6 5w-40, supertech filter, unknown drain
Kubota B7500 tractor 21hp diesel, T6 5w-40, purolator classic filter. Rotella 15w40 drain I think, kubota filter 245hrs. Last change at 201.
2 weeks before
Yamaha 350, Yamaha 600, Rotella t5 15w40
arctic cat 400, Rotella 15w40
Briggs push mower, valvoline 5w30
Coleman 3.5ke ohh5.5
Out: Super Tech 20w50/ hyper/sto
25+hard hours
In: traveler hdeo sae40/STP
Coldest start is 50degrees
Pusher Briggs 3.5-4hp
Out: unknown
In:. St hdeo sae36
Power washer
Briggs 3.75
Out: fs 5w-20/MMO
In:. Mobil 1 Truck and SUV 0w-20 mmo zddp
Honda GCV160 on a thirdhand Honda mower.
Out: whatever was in there from prior owner. It was nice and amber color.
In: Kirkland Synthetic 5W30
Manual says 10W30 or 5W30 and I had leftover 5W30 from the Chevy, so g2g I think?
12 year old Ryobi push mower with 6.5 hp B&S. Dumped the frankenbrew of whatever I add to it each time I use it. Have to add oil every time! Usually 5w30 synthetic of some leftover various quarts or T6 5w40. Decided to start new and filled with FVP 10w40 conventional from menards. Hoping the 10w40 doesn’t get consumed as quickly. So far so good. Mowed 2 hours and still at the full line.
