Post your latest small engine oil change
That's about what I do with my mower. I have a drip bottle that gets the remnants of all my family's oil changes. That gets poured into the mower and if need, topped off with 10w30. Mower is running great for 15 years so far!
Honda GCV160 in a pressure washer
Out: O’Reilly(Claumet) 10w30
In: Castrol Edge FST A3/B3/SL Euro 5w30
while this Honda is easy on oil, it was sheared down pretty well. I’m only running synthetics or HDEOs in OPE whenever possible. But I’m also a believer that fresh oil is better than old oil too.
Changed the oil in my B&S 5500W gen with the 342CC engine. Out B&S 5w30 Synthetic, about 45 hours on it, in Valvoline syn MaxLife Full Synthetic 10w30. I have a slow leak at the crankshaft seal, a common B&S problem it seems and maybe this will help, who knows. Second was my snow blower. 179cc PowerMore engine. Out was Rotella T 10w30, in the same. I'm set for power outages and snow 😉.
Whimsey
Brigg & Stratton 5500W generator, 342cc engine, out Brigg & Stratton 5w30 oil, in Valvoline Full Synthetic 10w30 HM Maxlife. It has an occasional leak from the crank shaft seal, a common B&S issue it seems, maybe this will help. Troy-Bilt 179cc 24" snow blower. Out Shell Rotella T 10w30, in the same.
1968 Gravely Commercial 10A walk behind tractor - 10hp Kohler K241
Engine: Out: Shell 10w30 (break-in for rebuild)
In: Rotella T 15w40
Transmission: Out: Rotella T 10w30/15w40 mix
In: Rotella T 15w40
1973 Ford LGT145 - 16hp Kohler K341
Out: black 5w30
In: Rotella T 15w40
Changed the oil in my Wen 56380i Sunday night when I got home from camping at the races. Oil had 54 hours on it.
Out: Mobil Super synthetic 5w30
In: Mobil Super synthetic 5w30
Briggs & Stratton 5500W gen: Out-B&S 5w30 synthetic - In Valvoline MaxLife Synthetic 10w30, it has a crankshaft seal leak.
Troy-Bilt snow blower, 179cc PowerMore, out Shell Rotella T 10w30- In the same.
2004 Miller Bobcat 225
Out: MFA 15w40 and Wix 51348
In: T6 5w40 and Wix 51348
Also new air filter and foam wrap, 33031 fuel filter and 2 new NGK spark plugs
2020 Timemaster
8 hrs on the oil, 13 hrs total.
Out: Shell RGT 5w30
In: Quaker State 10w30 (The factory fill bottle is used for measuring from the 5qt jugs)
2 Craftsman YTS 3000 riders
Both have 21 hp B&S OHV engines
Mower 1
Out: Pennzoil conventional 10w40, AcDelco PF53 filter
In: Amsoil Small Engine 10w30, Napa Proselect 21348 filter
Mower 2
Out: Quaker State High Mileage 10w30, Fram Extra Guard PH3614 filter
In: Amsoil Small Engine 10w30, Napa Gold 1348 filter
Old Murray rider
11 hp flathead B&S engine
Out: Pennzoil SAE 30 conventional
In: Amsoil Small Engine 10w40
Troy Bilt TB200 pusher
B&S 6.5 hp OHV engine
Out: Mobil 1 High Mileage 10w40
Husqvarna rider
24 hp B&S V-twin
Out: SL rated Havoline Synthetic 10w30, AcDelco PF53 filter
In: Napa Synthetic 10w30, Napa Proselect 21348 filter
